Specifies the IP address or fully qualified domain name for the agent host. For example: 192.#68.1.254.
You can specify a port along with the host name using either of the following formats:
Specifies the community under which the variable is accessed (for example, public).
Specifies the object ID for the variable. Object IDs (OIDs) are documented in the management information base (MIB) associated with a remote agent.
Specifies a data type for the variable. Select one of the list values to configure this operator parameter.
Specifies the value for the variable.
Specifies the version number for the remote SNMP Agent. Select Version 1 or Version 2 from the list.
