System functions returns values of several types. In a few cases, the return type depends on the input parameters or on whether the function is returning a “null”. In most cases, system functions return Java types rather than pure Javascript values. For instance, system functions that are described as returning a String are actually returning a Java.lang.String. Typically, you can ignore the difference between Java.lang.String and String. In some cases, this difference impacts behavior when executing and expression or script. In the case of typeof x, where x is a variable holding the returned value from a system function, the return type is “object”, rather than “string”.
For each system function return type, the following table describes the effect on the following variables:
System Function Return Type |
Javascript Variable Type after Assignment |
Dataset Variable Type Created |
boolean |
boolean |
Boolean |
C2OString |
object |
String |
C2OValue |
object |
ValueMap |
C2OValueArray |
object |
ValueMap |
C2OValueMap |
object |
ValueMap |
Date |
object |
Date |
int |
number |
Integer |
String |
object |
String |
String [] |
object |
String [] |
void |
undefined/a |
n/a |
