Enter the following data about the selected operation.
Note: Do not enter data for them if you have already entered data in the Parameter Expression and Parameter Namespace Expression fields.
Specifies the instance of the start request to abort.
Specifies the unique identifier of the connecting product that you want to cancel the request with.
Example: CA:00074 (CA Process Automation)
Specifies the unique identifier of the instance of the connecting product (as registered in the Catalyst Broker) that you want to cancel the request with.
Example: CA:00074:01
Specifies the unique ID of the product element instances.
Example: Process instance ID to cancel.
Specifies the ID of the task that you want to cancel.
Specifies information about the exported content.
Specifies
ObjectTypes: Lets you filter a specific object type.
Specifies the unique identifier of the connecting product.
Specifies the unique identifier of the instance of the connecting product (as registered in the Catalyst Broker).
Example: Process instance ID to be put on hold.
Specifies the CA Process Automation library location to import the .xml.
Example: /Testimport/
Specifies the location from where to import the .xml.
Example: C:\test_import\import_test.xml
Increase the version of the imported object if the same object exists in the specified import folder. Overrides the release version if the same release version exists.
Do not import objects with the same name as an existing object.
Import and replace the existing object. Deletes the previous versions of the object.
Boolean: true (sets the imported version to current) or false (set the imported version as not current).
Boolean: true (sets the imported version as available) or false (sets the imported version as not available).
Specifies the path that contains the name of the dataset that you want to run a query on.
Specifies the name of the CA Process Automation module properties that you want to configure.
Specifies the name of the CA Process Automation module.
Specifies whether the standard module configuration or custom module group configuration is returned. By default, the QueryModuleConfigs method returns all the available modules. The <ModuleType> attribute takes the following values:
Returns the standard modules and the custom modules configuration.
Returns only standard modules configuration.
Returns only custom modules configuration.
Specifies the path or the CA Process Automation library folder to query the start request forms.
Example: /SRF_test
Values:
Provide the start request forms Tags property as keywords to filter the list of start request forms.
Specifies the start request instance to query.
Specifies whether the start request instance is archived.
Values:
Specifies the ID of the task that you want to query.
Specifies the ROOTUUID of the process instance.
Specifies the process instance ID.
Specifics the state of the task, such as pending, taken, completed, failed, and timeout.
Example: Process instance ID to be released.
Specifies the ID of the task that you want to reply to.
Specifies the ID of the task that you want to approve.
Values:
Specifies the arguments/parameters and their value for the forms that is attached to the task.
Specifies the ID of the task that you want to return.
Example: Path to the process to start from the library.
Specifies the parameters and its values to be initialized when the process starts.
Specifies the name of the start request form to submit.
Specifies the path of the start request form to submit.
Specifies the parameters and their values to assign during when you submit the start request forms.
Specifies the start date of the start request form to submit.
Specifies the time that the start request form you want to submit began.
Specifies the priority of the start request form that you want to submit.
Specifies the ID of the task that you want to take.
Specifies the ID of the task that you want to transfer.
Specifies the user to transfer the task to.
Example: pamadmin or pamusers
Specifies the groups to transfer the task to.
Example: pamadmin groups, pamuser groups, pamdesigner groups
Specifies the name of the path for the dataset that contains the parameters that you want to update.
Specify a new parameter value for the dataset that you want to update.
