This example shows a user-defined Managed Bean Name and Managed Bean Attribute.
In the JMX Login Parameters, a remote JMX Service URL is provided. The Remote JMX Host, RMI Registry Port, and Remote JMX Server fields are disabled as a result.
The Remote JMX User and Remote JMX Password fields are blank, as the server does not have security enabled.
After the operator successfully executes, the State parameter returns as initial state from the MBean, as shown in the output dataset of the operator from the Dataset panel:
This information also appears in the operator output variable properties from the log panel:
