Defines the UCF Broker URL of your Catalyst server. Defaults to the UCF Broker URL in the Catalyst configuration.
Specify the Broker URL of the Catalyst Broker Service as:
http://<hostname>:7000/ucf/BrokerService
When using secure Catalyst communications, specify the secure broker URL as:
https://<hostname>:7443/ucf/BrokerService
Unique identifier of the connecting product.
Unique identifier of the instance of the connecting product as registered in the UCF Broker. CA Process Automation queries the UCF Broker for the list of connectors available and populate this field. You can then select your connector from the drop-down list.
Specifies the type of the entity. Values can be "Alert", "Item" or "Relationship".
For example:
entitytype=Item
Specifies the type of item. If not specified, then all types are retrieved.
For example:
itemtype=ComputerSystem
Specifies if the connector recursively includes the item and its constituent children and relationships.
Specifies a specific object identifier (same as the MdrElementID)
Specifies only objects that are updated after a specific time.
Specifies the maximum number of objects to retrieve before the operator completes.
