Directory Services › Update Object Attributes Operator › Operator Failure
Operator Failure
This operator fails in the following cases:
- The LDAP object specified does not exist.
- One of the LDAP attribute you want to add, replace, or remove does not exist
- The list of attributes and attribute values of the 'Add' or 'Modify' pages do not match in length.
- The user checked that an array of attributes and an array of attribute values are used for the 'Add', 'Replace', or 'Remove' pages, but the CA Process Automation object entered in the array field is actually not of type array (indexed strings).
- The LDAP server is setup to prevent any modifications of LDAP objects done programmatically.
- Unable to connect to the LDAP server.
