Directory Services › Create Object Operator › Operator Failure
Operator Failure
This operator fails in the following cases:
- The name of the new LDAP object is already used.
- Some of the mandatory attributes necessary to create the new LDAP object are missing.
- The "objectclass" of the new LDAP object is missing or incorrect.
- Some of the attributes being created for the object contain invalid values.
- Some of the attributes being created for the object do not apply to this type of object, for instance, you cannot add a 'mail' attribute to an LDAP object of type Organizational Unit.
- The path, under which the LDAP object is to be created, is invalid.
- The user checked that an array of attributes is used for the "objectclass" attribute, but the CA Process Automation object entered in the array field is actually not of type array (indexed strings).
- Unable to connect to the LDAP server.
