Returns the file name that you provided in the Response File field. This file contains the Response received from a SOAP call.
Returns the xpath query that is defined for extracting the data from the call results.
Returns the variable that is created to hold the extracted call results.
Returns the variable that holds the data type that the user defined to hold the call results.
Returns true when you select Extract SOAP Response Body to Dataset Variable, or false otherwise.
Returns true when you select Extract SOAP Header to Dataset Variable, or false otherwise.
Returns true when you select Extract First-Level SOAP Header Elements into Individual Dataset Variable, or false otherwise.
Returns true when you select Extract First-Level SOAP Header Elements into Individual Dataset Variables, or false otherwise.
Returns true when you select Strip XML Name Spaces from Response, or false otherwise.
