Defines the UCF Broker URL of your Catalyst server. Defaults to the UCF Broker URL in the Catalyst configuration.
Specify the Broker URL of the Catalyst Broker Service as:
http://<hostname>:7000/ucf/BrokerService
When using secure Catalyst communications, specify the secure broker URL as:
https://<hostname>:7443/ucf/BrokerService
Unique identifier of the connecting product.
Unique identifier of the instance of the connecting product as registered in the UCF Broker. CA Process Automation queries the UCF Broker for the list of connectors available and populate this field. You can then select your connector from the drop-down list.
Indicates whether the operator:
Or
Specifies the USM type of the object that is created or updated.
Alert, ComputerSystem, Router, Service, and so on.
For example:
itemtype=ComputerSystem
The operator parameters contain the properties of the USM type.
The Properties form can be customized using the "Product property configuration file name". If the MdrProduct and itemtype values match an entry in the "Product property configuration file name", then the form displays according to the following rules:
For example, this entry displays the Alert form as shown.
<!-- SCOM -->
<MdrTypes MdrProduct="CA:00031">
<TypeMap name="Alert">
<Mapping propName="MdrProdInstance" aliasName="siloHost" />
<Mapping propName="MdrElementId" aliasName="Id" />
<Mapping propName="UrlParams" aliasName="" />
<Mapping propName="SeverityTrend" aliasName="" />
<Mapping propName="RelatedAlerts" aliasName="" />
<Mapping propName="AlertedMdrProdInstance" aliasName="siloHost" />
<Mapping propName="AlertedMdrElementID" aliasName="MonitoringObjectId" />
<Mapping propName="Summary" aliasName="Name" />
<Mapping propName="Message" aliasName="Description" />
<Mapping propName="Assignee" aliasName="Owner" />
</TypeMap>
</MdrTypes>
The tooltip of properties with alias names indicates the USM property name.
