Standard Operators › Reset Operator › How the Reset Operator Works with the Loop Operator
The Reset operator works with the Loop operator as follows.
- The Reset operator allows the Loop operator to be reset. The Reset operator resets the Loop operator as follows:
- Resets all operators inside the Loop operator.
- Resets the Loop operator to the first iteration.
- After the reset, the Loop operator restarts from the first iteration.
Note: The Loop operator does not support simulation. The Reset operator always resets a Loop operator regardless of the values of the fields:
- Continue with Result
- End Condition
- Evaluate pre-execution and post-execution code
