Select to provide a list of paths to the required external JARS in the External Jar Paths as Expression field.
Clear to provide the paths to the required external JARs as an expression, that is, as a dataset variable in the External Jar Paths as Expression field.
This check box is selected by default.
Specifies the list of paths to the external JARs that are required by the main method code of the operator, if any.
The Invoke Java operator loads the JARs listed in this field. Any JAR entered in this list is available to the Java code executed by the operator. The classes defined in the operator-level JARs override the same classes specified in the JARs at the operator category level.
For each path, you can:
Do not start the JAR file relative path with:
Otherwise, CA Process Automation assumes that the JAR file path is a full path.
Resources within CA Process Automation, including user resources, are mirrored within the mirroring interval of the agent. Verify that the JARs uploaded in the user resources are already mirrored before using them in the Invoke Java operator.
In addition to external JARS, you could load .class files as follows:
For example, if MyAccount.java does not belong to a package, and MyAccount.class is located at:
C:\java\tests\MyAccount.class
...then set the operator to use the following path:
C:\\java\\tests
For example, if MyAccount.java belongs to package com.ca.tech, and MyAccount .class is located at: C:\java\othertests\com\ca\tech\MyAccount.class
C:\\java\\othertests
If you specify the path to a directory (to load .class files), enter it as a full path. You can also enter it as a relative path to CA Process Automation User Resources. Do not enter the path as an HTTP path.
Specify the path to a directory to load .class files, not JAR files. Unlike .class files, each JAR file requires a separate path that ends with the JAR file (not the directory where it resides).
Specifies the indexed string dataset variable that contains the list of paths to the external JARs required by the main method code of the operator, if any.
Select to provide the Java code in the Required Main Method field.
Clear to provide the Java code as a dataset variable in the Required Main Method as Expression field.
Specifies the Java code text of the main method. You can browse to locate any file that contains this code. The main method consists of normal Java statements and expressions. You must initialize and use objects defined in the Java SDK or the external JARs.
Note: CA Process Automation parses the code and checks for its structural validation when you click OK. An error message displays if an error is found in the structure of the code.
Specifies the dataset variable that contains the content of the main method. The main method consists of normal Java statements and expressions. You must initialize and use objects defined in the Java SDK or the external JARs. No structural validation is performed.
Set this field (to something different than default) if your main method/external JARs rely on the Java context class loader to load classes. Set the Java context class loader to either the operator class loader or the module class loader to avoid a ClassCastException.
The Invoke Java operator uses a chain of class loaders to load classes while running the Java code. This chain was designed as follows (among other class loaders):
The operator consults each class loader before moving to the next (if the class is not found).
This chain works as long as the code that you execute does not explicitly use its own class loader to load a class. In this case, you see in the logs a 'ClassCastException'.
Example:
Consider class MyChildXMLParser extends class MyParentXMLParser. The following code fragment listed creates a MyParentXMLParser by using a Java factory. This factory actually loads and creates a MyChildXMLParser, which is then cast into a MyParentXMLParser object:
public MyParentXMLParser() {
super((MyParentXMLParser)ObjectFactory.createObject("com.ca.parser.MyChildXMLParser"));
In this example, consider:
To resolve this issue, set the field ‘Set Context Class Loader’ to either:
Note: "0 : Default" is used in all other cases where your Java code does not explicitly load classes using its own class loader. This value is the default value of this field.
By setting the context class loader to the class loader of the Invoke Java operator, the Java factories that are called by the user’s code are forced to use the Invoke Java operator class loader. This action removes ClassCastException.
