The operator finishes successfully.
The operator fails due to any of the following reasons:
The Invoke Java operator is typically used in a way where you specify external jar paths in the operator or module. You must also enter java code in the main method of the operator. This code uses the objects that you defined in the external jar files.
Available if set by the user during the process design.
