Specifies the distinguished name of the object under which you want to create the new group object.
Specifies the name of the group you want to create. This is the CN attribute of the group.
Specifies the type of LDAP group. Select either group, group of names, or group of unique names.
When checked, then the array of members is used for this request.
Specifies the array of members of the group (required for Group of Names or Group of Unique Names in Active Directory). This field is enabled only when the Use the specified array field for the Group Members field is checked.
Specifies the members of the group (required for Group of Names or Group of Unique Names in Active Directory). This field is enabled only when the Use the specified array field for the Group Members field is unchecked.
Check if we are creating an object of type 'Group', as specified in the LDAP Group Type, in an Active Directory server. For an object "Group" in Active Directory, we can set two extra attributes: Group Scope and Group Type.
Specifies the scope of the group that is created in an Active Directory. Select either Domain Local, Global, or Universal. This field is enabled only when you select the Creating an object of type 'Group' in Active Directory? check box.
Specifies the type of the group that is created in an Active Directory. Select either Security or Distribution. This field is enabled only when the Creating an object of type 'Group' in Active Directory? field is checked.
