The actual Switch User Pasword Text Prompt read from the SSH session within the time to wait for prompts. This is the data that was matched against the pattern specified in the Switch User Pasword Text Prompt field. This field is empty if switching the user did not require a password, such as when switching from Root to any other user, or if the operator is not set up to switch users.
The actual Switch User Command Prompt read from the SSH session (within the time to wait for prompts ) the first time after switching to the new user. This is the data that was matched against the pattern specified in the Switch User Command Prompt field. This field is empty if the operator is not set up to switch users.
An indexed String containing the output read from each command (within the time to wait for prompts) that ran on the remote host. The output for each command is truncated to the value specified in Commands Output Size limit.
The full output of each command contains the next prompt.
