Each variable in the Output Variable Names list is created with the corresponding CA Process Automation type.
If a variable name in the Output Variable Names does not exist in the script, the Run Telnet Script operator creates the corresponding variable as an empty string.
The bean shell interpreter provides a robust environment for the script. For example, if the bean shell script throws an exception or contains an error, the variables defined and initialized in the script, before the occurrence of the error, can be retrieved with their values. Alternatively, if the javascript script throws an exception or contains an error, the javascript interpreter does not allow for any variable to be retrieved with its value.
Output parameters include the following:
