Specifies an array of value maps containing the network interfaces associated with the local host.
Each value map in NetworkInterfaces contains the following information:
Specifies the name of the network interface.
Specifies the display name of the network interface.
Specifies the hardware address, usually MAC address, of the network interface. A blank in this field indicates that the operator is unable to retrieve the MAC address from the network interface. The retrieve failure can be due to lack of privileges or can be due to the lack of a MAC address for this network interface.
Specifies an array of value maps containing the InetAddresses associated with the network interface. Each value map in InetAddresses contains the following information:
IpAddress
Specifies the IP address.
Host
Specifies the host name. The IP address is returned if the operator is unable to perform a reverse lookup due to network setup.
CanonicalName
Specifies the canonical name. If the operator is unable to retrieve the FQDN, an IP address is returned.
One of the following items:
Indicates that the operator finished successfully.
Indicates that the operator failed.
Specifies why the operator failed in an error message.
