Specifies the name of the event. This expression is matched against Name of the Event. This name can be a regular expression, a partial match that is based on user choice, or both.
Specifies the type of event (optional). This expression is matched against Type of the Event. This type can be a regular expression, a partial match that is based on user choice, or both.
Specifies the source of the event. This expression is matched against Source of the Event. This source can be a regular expression, a partial match that is based on user choice, or both.
Specifies the name of the Event destination (optional). This expression is matched against Destination of the event. This destination can be a regular expression, a partial match that is based on user choice, or both.
Specifies a CA Process Automation Boolean expression for additional event parameters (optional). This expression is matched against Event Parameters field of Event. Event Parameters can be accessed using a "payload" keyword (for example, payload.ticketId=="1443132").
Note: This field includes dataset assistance when using of any of the keywords.
When selected, the Monitor Event operator receives all events, instead of the first one that matches. Once these events are delivered, they are never sent to you again. Any event that is delivered to you and is also marked as ‘deliver to single subscriber’ is invalidated and is not delivered to anybody else.
Enables pattern matching against the respective event attributes like Name, Type, Source and Destination.
Allows a partial match against the respective event attributes like Name, Type, Source and Destination.
