The Remove Attributes Parameters page is used to enter all the attributes that you want to remove from the LDAP object.
Check this box to use Attributes arrays for this request.
Specifies the array containing the LDAP names of the attributes to be removed from the object. This Dataset field must be defined as an array (indexed string). If Use specified array field for the LDAP attributes to be added is checked, this field will be used.
Specifies the LDAP names of the attributes to be removed from the object. If Use specified array field for the LDAP attributes to be added is unchecked, this field will be used.
