The existsDataset function checks whether a dataset object exists in the given path. The path can be an absolute/relative path. The relative path is relative to the process in which the script is executed.
Syntax
bExists = existsDataset(datasetPath)
Arguments
Specifies the full/relative path of the dataset whose existence needs to be checked.
Return Value
Returns true if the dataset object exists or false if it does not.
Example
if (existsDataset(datasetPath))
Process.mseg_dataset= "Dataset Common exists" ;
else
Process.mseg_dataset= "Dataset Common does not exist" ;
