Some common LDAP attributes are listed below. The complete list of LDAP object classes and attributes used in the LDAP server schema is located on the LDAP server.
LDAP Attribute Name |
Description |
cn |
Common Name attribute, which contains the name of the object |
dc |
Domain Component attribute |
objectClass |
Object Class attribute, which contains the LDAP type(s) of the object |
distinguishedName |
Distinguished Name attribute in Active Directory This is the attribute that uniquely identifies the object in the Active Directory. |
entrydn |
Distinguished Name attribute in LDAP servers (other than Active Directory) This is the attribute that uniquely identifies the object in an LDAP server. |
o |
Organization Name attribute which contains the name of the organization |
ou |
Organizational Unit Name attribute which contains the name of the organizational unit |
sn |
Surname attribute which contains the family name of an individual |
givenName |
First name attribute which contains the first name of an individual |
personalTitle |
Personal Title attribute which contains the personal title of a person Examples of personal titles are "Mr", "Dr", "Prof" and "Rev". |
initials |
Initials attribute which contains the initials of some or all of an individual's names, but not the surname(s) |
uid |
User ID attribute |
userPassword |
Password attribute which contains a user's password Passwords are stored using an Octet String syntax and are not encrypted. |
title |
Title attribute which specifies the designated position or function of the object within the organization |
Mail attribute which contains a user's email address |
company |
Company or organization name attribute |
department |
Department Name attribute |
manager |
Boss, manager attribute |
mobile |
Mobile Phone number attribute |
homephone |
Home Phone number attribute |
telephoneNumber |
Telephone Number attribute |
facsimileTelephoneNumber |
Fax Number attribute |
postalAddress |
Postal Address attribute, which contains information required for the physical delivery of postal messages |
postalCode |
Postal Code attribute If this attribute value is present it will be part of the object's postal address. |
c |
Country Name attribute which contains a two-letter ISO 3166 country code |
l |
Locality Name attribute which contains the name of a locality, such as a city, county or other geographic region |
st |
State Or Province Name attribute |
street |
Street attribute which contains the physical address of the object, such as an address for package delivery |
owner |
Owner attribute which specifies the name of some object which has some responsibility for the associated object The value is a Distinguished Name |
description |
Description attribute which contains a human-readable description of the object |
seeAlso |
See Also attribute. |
serialNumber |
Serial Number attribute which stores the serial number of a device |
member |
The member attribute is used in entries defining groups It has Distinguished Name syntax, so each value is effectively a pointer to another entry in the directory. Note that the standard groupOfNames object class makes the member attribute mandatory. As attributes cannot have empty values, this effectively requires all groups to have at least one member at all times. |
uniqueMember |
The uniqueMember attribute is similar to the Member attribute stated above, and it is used to store the unique members in a groupOfUniqueNames object |
sAMAccountName |
Old NT 4.0 logon name attribute (Active Directory only), which must be unique in an Active Directory domain |
LastLogonTimeStamp |
Last Logon Time Stamp attribute (Active Directory 2003/2008 only), which contains the last logon date of a user; but it is replicated across all domain controllers only after a period of time defined in the msDS-LogonTimeSyncInterval attribute of the Active Directory |
LastLogon |
Last Logon attribute (Active Directory only), which contains the last logon date of a user but it is NOT replicated across all domain controllers |
