To add an SSL certificate to CA Process Automation
For instance, to establish an SSL connection between CA Process Automation and an Active Directory server, retrieve the certificate. Log in to the http://i.p./certsrv where i.p. is the IP address of the Active Directory server, then download the certificate.
Note: If the jssecacerts file exists in the jre/lib/security directory, import the certificate in the jssecacerts file as shown in step 3.B and specify “jssecacerts” in the trustStore flag in step 4.B. Else, import the certificate in the cacerts file as shown in step 3.A and specify “cacerts” in the trustStore flag in step 4.A.
OR
Where certnew.cer is the path to the certificate file retrieved in step 1.
"C:\\Program Files\\Java\\jdk1.6.0_03\\jre\\lib\\security\\cacerts" is the path to the cacerts file within the Java JRE or JDK.
PAM\server\c2o\bin\c2osvcw.conf
(or in the case of an upgrade): I
PAM_DIR%\server\c2o\bin\c2osvcw.conf:
OR
wrapper.java.additional.12=-Djavax.net.ssl.trustStorePassword="changeit"
The numbers might be different for you. Start with the next available number. If wrapper.java.additional.11 is already defined, use 12 and 13.
The program folder is different for your JDK installation.
The password is "changeit".
Set Up the Active Directory Server
To establish an SSL connection between the CA Process Automation-Directory Services operators and an Active Directory server, verify that the Active Directory server is set up:
Note: When you create a new user account or modify the password of an existing user account in Active Directory, the Active Directory does not allow you to create or modify a user password unless CA Process Automation is connected to the Active Directory server through SSL.
