Sometimes an action attempts to take more units of a resource than are available or tries to lock an already locked resource. In these situations, set the Time-out interval to determine how long the operator waits for resources to become available. After the time-out interval expires, the operator checks one final time if the resource is available before it times out. After a Resources operator times out, the process module processes the time-out exit link on the operator.
When checked, the operator waits indefinitely until all resources including all the actions listed under Actions can be executed and are available.
When clear, a Duration or Target Date timeout setting is applied.
Select Duration or Target Date. The operator waits before timing out. For example, to specify a time-out interval, select Duration and enter the number of seconds. When you specify a time-out duration of 0 seconds, the operator does not wait. If resources are unavailable, it immediately times out. The operator succeeds only if resources are immediately available.
Specify the numeric quantity of seconds or a fixed date and time to serve as the timeout period.
Select Continue, Reset, Abort, or Abandon. If you choose Abort, the operator processes the Failed exit link.
