Datasets and Parameters › Process Parameters › Calculated Parameters › JavaScript Operators › Arithmetic Operators
JavaScript uses the following operators to combine integer values:
Operator
Description
Multiplication
Division
Addition or unary plus
Subtraction or unary minus
Modulo
Increment
Decrement
Arithmetic calculations in an expression follow algebraic rules:
- When an expression contains multiple arithmetic operators, multiplication and division are calculated first, then subtraction and addition.
- When operators are of the same order, they are calculated from left to right.
- You can use parentheses to change the precedence. Calculations inside parentheses are evaluated first. If parentheses are nested, the most deeply nested calculation has precedence.
