Calendars, Schedules, Tasks, and Triggers › Calendars › The Advanced Calendar Designer › Add and Remove Calendar Dates Manually
You may sometimes require dates in a Calendar object that are not easily specified by a calendar rule. Similarly, a rule can include dates that for some reason you do not want in a calendar. You can use the Manually Included Dates and Manually Excluded Dates in the Selected Calendar Rules pane to add or remove selected dates manually.
To add or remove dates
- Open a calendar.
- Click the Advanced tab.
- Expand Manually Included Dates or Manually Excluded Dates.
- In the month viewer in the Properties pane, right-click a selected date and click one of the include or exclude date commands on the shortcut menu.
- To include specific dates for a particular year, click the Include Full Date Command.
- To include anniversary dates for all years, click the Include Anniversary Date Command.
- To exclude specific dates for a particular year, click the Exclude Full Date Command.
- To exclude anniversary dates for all years, click the Exclude Anniversary Date Command.
The Include Full Date command is only available when excluded dates are selected in the pane. The Exclude Full Date command is only available when included dates are selected in the pane.
