CA Process Automation uses standard Java date and time format pattern strings. Within date and time pattern strings, unquoted letters from 'A' to 'Z' and from 'a' to 'z' are interpreted as pattern letters representing the components of a date or time string. Text can be quoted using single quotes (') or double quotes (") to avoid interpretation. "''" represents a single quote. All other characters are not interpreted; they are copied into the output string during formatting or matched against the input string during parsing.
Letter |
Date or Time Component |
Presentation |
Examples |
G |
Era designator |
Text |
AD |
y |
Year |
Year |
2009; 09 |
M |
Month in year |
Month |
July; 07 |
w |
Week in year |
Number |
27 |
W |
Week in month |
Number |
2 |
D |
Day in year |
Number |
189 |
d |
Day in month |
Number |
10 |
F |
Day of week in month |
Number |
2 |
E |
Day of week |
Text |
Tuesday; Tue |
a |
AM/PM marker |
Text |
PM |
H |
Hour in day (0-23) |
Number |
0 |
k |
Hour in day (1-24) |
Number |
24 |
K |
Hour in AM/PM (0-11) |
Number |
0 |
h |
Hour in AM/PM (1-12) |
Number |
12 |
m |
Minute in hour |
Number |
30 |
s |
Second in minute |
Number |
55 |
S |
Millisecond |
Number |
978 |
z |
Time zone |
General time zone |
Pacific Standard Time; PST; GMT-08:00 |
Z |
Time zone |
RFC 822 time zone |
-0800 |
Patterns are usually repeated; their number determines the exact presentation as shown in the following table:
Presentation |
Formatting |
Text |
If the number of pattern letters is 4 or more, the full form is used; otherwise a short or abbreviated form is accepted, independent of the number of pattern letters. |
Number |
The number of pattern letters is the minimum number of digits, and shorter numbers are zero-padded to this amount. During parsing the number of pattern letters is ignored unless it is needed to separate two adjacent fields. |
Year |
If the number of pattern letters is 2, the year is truncated to 2 digits; otherwise it is interpreted as a number. During parsing, if the number of pattern letters is more than 2, the year is interpreted literally, regardless of the number of digits. So using the pattern "MM/dd/yyyy", "01/11/12" parses to Jan 11, 12 A.D. |
Month |
If the number of pattern letters is 3 or more, the month is interpreted as text; otherwise, it is interpreted as a number. |
General Time Zone |
Time zones are interpreted as text if they have names. For time zones representing a GMT offset value, the following syntax is used:
Digit Digit Digit
Digit Digit
0 1 2 3 4 5 6 7 8 9 The format is locale independent and must be taken from the Basic Latin block of the Unicode standard. |
RFC 822 time zone |
A four digit time zone format is used:
Sing TwoDigitHours Minutes
SimpleDateFormat also supports localized date and time pattern strings. In these strings, the pattern letters described above may be replaced with other, locale dependent, and pattern letters. SimpleDateFormat does not deal with the localization of text other than the pattern letters; that is up to the client of the class.
The following examples show how date and time patterns are interpreted in the US English locale. The given date and time are 2009-07-04 12:08:56 in the US Pacific time zone.
Date and Time Pattern |
Result |
"yyyy.MM.dd G 'at' HH:mm:ss z" |
2009.07.04 AD at 12:08:56 PDT |
"EEE, MMM d, ''yy" |
Wed, Jul 4, '09 |
"h:mm a" |
12:08 PM |
"hh 'o''clock' a, zzzz" |
12 o'clock PM, Pacific Daylight Time |
"K:mm a, z" |
0:08 PM, PDT |
"yyyyy.MMMMM.dd GGG hh:mm aaa" |
02009.July.04 AD 12:08 PM |
"EEE, d MMM yyyy HH:mm:ss Z" |
Wed, 4 Jul 2009 12:08:56 -0700 |
"yyMMddHHmmssZ" |
010704120856-0700 |
"yyyy-MM-dd'T'HH:mm:ss.SSSZ" |
2009-07-04T12:08:56.235-0700 |
