The UNIX script example creates two indexed fields, HostList and OSList in the UnixGetInfo operator dataset. It reads the source file line-by-line and assigns host names ($host) to indexed values in sequential HostList fields and operating systems ($opsys) to indexed values in sequentially numbered OSList fields, starting with 0, and finishing at one less than the number of rows read from the source file.
The UNIX Shell script parameter variables $1, $2, etc. are set by the first, second, etc., entries of the Parameters input area of the calling Run Script operator. In this case, only one parameter is being passed, which is used to set SourceFile. The number of rows read are assigned to the operator dataset variable named NumRowsRead. The sleep 30 line has no purpose other than to pause the operator and give the user 30 seconds to examine the folders and files created in the C2OSVD location. This line would not be included in a production script.
#!/bin/ksh
SourceFile=$1
#known to be reading 2 variables, host and operating system
mkdir $C2OSVD/HostList
mkdir $C2OSVD/OSList
integer counter=0
while read host opsys; do
echo -n $host > $C2OSVD/HostList/${counter}
echo -n $opsys > $C2OSVD/OSList/${counter}
counter=$counter+1
done < $SourceFile
echo -n $counter > $C2OSVD/NumRowsRead
sleep 30
exit 0
