Datasets and Parameters › Datasets › Create a Named Dataset Object
You create and manage named dataset objects with your other automation objects in the Library Browser.
- Click the Library tab.
- In the Library Browser folders pane, select a folder.
- In the toolbar, click New and select Dataset.
A new dataset object appears and is checked out to you.
- Enter a name for the new dataset.
- Double-click the dataset to define its pages and fields.
The Dataset dialog opens.
