Designing Processes › Document a Process › Change and Display Operator Information in a Process
The name is included in a text field that optionally labels an operator on a process. The operator Text property defines this field. The Operator Information option on the View menu hides or displays this text field next to operators in a process.
To generate a default value for the Text property, CA Process Automation combines the Operator Name and Operator Parameter settings.
- Double-click an operator in a process.
- In the Information properties Name field on the Properties palette, enter the text to appear next to the operator in the process.
Note: Use the other settings on the Properties pane Information tab to:
- Specify a custom icon instead of the default icon for the operator.
- Override the object preferences for automatically or manually updated text that is displayed with the operator.
- Set the text position, background color, font, and alignment.
