Designing Processes › Process Operator Ports and Links › Add Operator Ports and Links
Place a link between operators to establish the logical flow. For example, link the Start operator to the next operator to begin a process flow. Links connect one of any number of exit ports on one operator to the single fixed entry port of another.
- Open a process.
The Process Designer tab appears. If not already checked out, click Check Out.
- Identify a source operator, its exit port, and a destination operator's entry port.
- On the source operator, if the exit port you want does not appear, right-click the operator and then click the port you want to add. Port types vary by operator. Examples include Failed, Completed, After, and Custom.
A new color-coded exit port appears on the operator's border.
- Click the exit port on the source operator and drag the link to the entry port of the destination operator.
A new link appears between the two operators.
- Repeat these steps, adding links and, if necessary, ports between operators to define the process flow.
- In the toolbar, click Save.
