Library Browser › Working with Objects and Folders › Copy and Paste an Object or a Folder
You can copy objects or folders. You can use a current object version as the basis for similarly configured objects on the same Orchestrator. Copy a current object version to the same or a different folder where you can rename and edit it as a new object. For example, you can configure a custom operator object and then add copies of it within a library.
- Click the Library tab.
- Identify the objects to copy in the main window. Verify that the version you want is marked as the current version.
- Select one or more source objects or folders and click
Copy.
- In the Library Browser folder pane, click a destination folder in the same automation library, then click
Paste.
Notice the following results:
- CA Process Automation adds the copied objects with the same names as the original objects.
- Each object has one version, the version that was copied.
- If the copied version has a Release Version value, the copy retains that value.
- If the copied version was baselined, the copy is baselined.
- If this location is the same as the source folder, then CA Process Automation appends a number to each object name (for example, Process_1).
- (Optional) Rename the new objects.
