When you complete your changes, check in the object to save them to the same or a new object version.
After you complete the following procedure, the Designer remains open and you can continue viewing the object in read-only mode. Check out the object again to make more changes.
The Check In dialog appears with the object name in the Object Name field.
Selected: Make the checked-in version the current version of the object. The current version is the version that CA Process Automation uses.
Cleared: Retain the previously current version as the current version. Clear the check box if you are checking in an object for which design is in progress.
Selected: The object version that you are checking in cannot be changed during a future checkout. Baseline versions can only be the basis of new versions. You can check out a baseline version, change it, and check in the object as a new version.
Cleared: The object version that you are checking in can be changed during a future checkout.
Displays the object version that you are checking in.
Defines a unique indicator for an object version that is selected for export as part of a release.
If the Release Version field is read-only, the object was imported previously with the release version in nonmodifiable mode. The tooltip provides details.
Enter a value for Release Version only when you are preparing the object version for export (alone, in a folder). Enter a release-specific value so that there is no conflict with any release version value for an existing object in the import environment.
Note: If a conflict occurs, the import fails. Specifically, the import fails under the following conditions:
(Optional) Enter descriptive comments to save with this version of the object.
Specifies whether to create a version of the object or apply the changes to the same version.
New Version: Creates a version of the object.
Same Version: Overwrites the current version of the object with changes made since it was last checked out.
Note: If you try to check in changes for a baselined object, CA Process Automation displays an error message.
