Introduction to Process Automation › Phase II: Design and Implementation › Optimize for Modularity and Component Reuse › Custom Operators
Custom Operators
You can base a custom operator object on any of the other operators available in your environment. Use custom operators to:
- Facilitate reuse: Use the same operator with the same configuration settings in different processes.
- Save the settings for a task: You can preconfigure custom operators to perform specific tasks. For example, you can define a custom operator to work with an application that is already installed on your system.
- Interact with enterprise applications: You can export a folder as a content package to support common enterprise applications.
You can modify your custom operator without changing the original operator.
