Previous Topic: ca_pam_setTableData(_id, values)Next Topic: Simple Array
ca_pam_setTableDataFromJSObject(_id, values)
Populates a table with the JavaScript object array.
Input Parameters
_id (string)
Specifies the table ID.
values (object)
Specifies the JavaScript array containing a list of objects. The objects properties must be same as the column name to populate the data.
Return Value
None.
Example
This example shows how to populate a table from a JavaScript object array. The table ID is Form.name and has two columns as firstName and lastName.
var tableData = new Array();
var data1 = new Object();
data1.firstName = "firstName1";
data1.lastName = "lastName1";
tableData[0] = data1;
var data2 = new Object();
data2.firstName = "firstName2";
data2.lastName = "lastName2";
tableData[1] = data2;
ca_pam_setTableDataFromJSObject('Form.names',tableData );
You can also find this function in the out-of-the-box content in CA Process Automation.
  1. On the Home page, click Browse Out-of-the-Box Content.
  2. Navigate to the User Interaction Forms folders, then:
    • 07 Populate Table RESTful WS: Populate Table RESTful WS.
    • 08 Populate Table SOAP WS: Populate Table SOAP WS.
