Returns the value of the Date field Minimum Value property, expressed as a long integer. This integer represents the number of milliseconds before or after January 1, 1970 00:00:00 UTC (known as the UNIX Epoch). You can pass the value in this field, as mentioned in the ca_pam_getDateFieldMaxValue(_id) method.
Specifies the unique identifier of a Date field.
The minimum value for a Date field, expressed as a long integer.
ca_pam_getDateFieldMinValueInMillis('Form.DateofBirth')
This example returns the minimum value that is allowed for the DateofBirth field as a numeric string measured in milliseconds. For a Date field with a minimum value of 01/01/1974, this function would return 126291600000 (that is, 126,291,600,000 or 126 billion milliseconds).
This function returns a negative result for dates before 1970.
