Operators and Icons › Operators › Custom Operators › How to Work with Protected Custom Operators
CA Technologies can release protected custom operators. The lock icon indicates that the custom operator is protected:
The use of protected custom operators is restricted in the following respects:
- You cannot view any code defined to the protected custom operator. The input parameters, pre-execution code, and post-execution code are encrypted.
- You cannot modify the imported version.
- You cannot modify or view the code in a copy of the imported version.
