A release occurs when you deploy a process and its components from a design environment to a production environment. When you select components to package for export, you select one version of each component. You can enter a release-specific value in the Release Version field of the version of each folder and object you plan to package for export. This practice is required when you export objects in a folder as a content package.
After you set a release version for each object, you can add a corresponding version to the folder to export as a content package.
Content packages begin as folders in the initial CA Process Automation environment. When you export a folder as a content package and you import it to a new environment, the product baselines the imported object versions in the content package. Users cannot modify the Release Version data of imported objects.
