Datasets and Parameters › Datasets › View or Copy a Dataset Expression
Use this procedure to view or copy the full reference to a dataset array or a specific value.
- Click the Library tab.
- In the Library, do one of the following actions:
- Double-click a dataset.
- Right-click a dataset and click Edit.
- Right-click a dataset and click Modify Dataset.
- In the resulting window, click an array or a specific variable to view it.
- Right-click the array or variable and click View Expression.
The Dataset Expression window opens.
- View or copy the expression. You can also drag the expression to a destination field that accepts expressions and supports drag-and-drop.
