The Custom Panels tab appears for a limited subset of base operators only, such as the Assign User Task or Invoke SOAP Method operators. The sections on the tab vary by base operator. Two common base operators appear in the following examples.
For custom operators based on the Assign User Task operator, the Custom Panels tab is divided into the following sections:
Specifies the users or groups that can interact with the custom operator and its form.
Specifies the users or groups that are available for task transfer or delegation.
Specifies the Title, Description, and Form Data Initialization Code for the associated Interaction Request Form.
For custom operators based on the Invoke SOAP Method operator, the Custom Panels tab is divided into the following sections:
Use this group of fields to specify the Service URL, method name, user name, password, version, source, and other details for basic SOAP or HTTP authentication. Use the WSDL Wizard to load a URL and select WSDL services, ports, and operations.
Use this group of fields to specify the parameter style and add, edit, or delete macros or XPath queries.
Use this group of fields to specify the saved SOAP request response file path and add, edit, or delete additional extracted data. You can also check options to determine how portions of the extracted SOAP body, header, and XML namespaces are handled.
Use this group of fields to specify an expression or add, edit, and delete content as MIME attachments.
Use this large group of fields to manage security details. Expand each group box by clicking its title to view all the fields.
