Operators and Icons › Operators › Custom Operators › Custom Operator Properties › Custom Operator: Form Tab
When designing a custom operator, you can permit custom parameters and pages to receive input from end users as they configure your custom operator in a process or schedule. Use the Custom Operator Form tab to:
- Add, remove, and rename property pages
- Add, remove, and rename parameters on the property pages
- Configure the characteristics of a parameter
- Reorder parameters on a property page
- Move parameters between pages
Each custom operator can have one or more pages of parameters that are based on its ancestor or base operator. You can modify and configure these parameters. For example, if the base is the Run Script operator, you can configure the following parameters:
- The scriptType field to define the extension of the script
- The inLineScript field to define the script itself
- The other fields and parameters standard for the Run Script operator
