Datasets and Parameters › Process Parameters › Operator Properties › Dataset Variables in Parameters › Use Dataset Variable Name Assistance
Use the Dataset Variable Name Assistance feature in various supported contexts throughout the application.
- Open and check out the automation object to edit. For example, a process, form, or dataset.
- Press Tab or click in a text field that accepts expressions.
- Press Ctrl + Space.
A list of suggested values appears.
- Select the value to use. To select process or operator dataset variables, enter the following string value in the text field:
Process.
- Enter an operator name for operator-specific variable name assistance.
- To filter data based on text input, begin typing or entering characters.
The list of suggestions dynamically updates as you enter text.
- Select the values to use.
