Create new automation objects in specific folders in the library that is associated with an orchestrator. After you create an object, you can edit its properties.
A new object is created.
The application alerts you when the specified name is already associated with another object in the folder.
Note: To set rights and perform other object tasks, the best practice is to organize the objects in folders. Do not create objects at the root level because you cannot manage such objects as a group.
Note: The package object is no longer supported CA Process Automation 4.2.00. A content designer can now bundle the automation objects in a folder and export objects as content package for deployment in a production environment. The usage of the existing package object is kept for backward compatibility. See How to Migrate Objects From a Package to a New Folder to Prepare for Export.
