Designing Processes › Navigate to a Specific Part of a Process
When working with long processes, use the Navigator window to help you adjust your current view. Panning a smaller view of a process is more convenient than scrolling through the entire process in the main window.
- Open a process.
- In the Process Designer, check Navigator from the View menu.
The Navigator window shows a miniature image of your process.
- Drag the rectangular frame over the portion of the process that you want to view.
The main window shows an enlarged view of the selected area.
- To adjust the miniature view of your process, drag the square at the bottom right corner.
- To resize the Navigation palette, drag any edge or corner the same way you resize any palette.
