If Operators Auto Recovery is selected (the default), you do not have to initiate the recovery. Each Orchestrator in the environment detects that the agent or Orchestrator is active and runs the recovery. Each Orchestrator runs recovery on any enabled touchpoint, host group, or Orchestrator that is mapped to the agent or Orchestrator in the environment.
When an agent is mapped to many touchpoints, the Orchestrators run the recovery on all enabled touchpoints that are mapped to the agent. When an agent or Orchestrator becomes active, the Domain Orchestrator broadcasts the changes to the other Orchestrators. In a clustered setup, only the master node runs the recovery.
Example: Automatic Recovery
Consider the following scenario, in which an agent is mapped to the following touchpoints and host groups in an environment:
Assume that all touchpoints and host groups are enabled and that only the following touchpoints and host groups are set to Operators Auto Recovery:
When the agent becomes active, each Orchestrator in the environment tries to run the automatic recovery on the three touchpoints.
Assume there are two Orchestrators in the environment:
2010-06-28 19:22:59,984 DEBUG [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Checking whether to initiate Touchpoint/Orchestrator Recovery of 'System_Error' operators in 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set), that ran against Agent/Server ID: f3492322-5517-4a21-8a19-92838ccb3f65
2011-03-28 19:22:59,984 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: HG_user01-w500 Recovery... Recovering 'System_Error' Operators that ran against: HG_user01-w500 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set). 2011-03-28 19:22:59,984 DEBUG [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieve the processes (with enabled auto recovery flag) that are in 'Waiting' or ‘Running’ or 'Blocked' states and contain operators in 'System Error' when ran against: HG_user01-w500
2011-03-28 19:23:00,000 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 0 processes to recover for HG_user01-w500 recovery. 2011-03-28 19:23:00,000 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Found no Processes to recover for Touchpoint/Orchestrator: HG_user01-w500 Recovery.
2011-03-28 19:23:00,000 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: TP_user01-w500 Recovery... Recovering 'System_Error' Operators that ran against: TP_user01-w500 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set). 2011-03-28 19:23:00,000 DEBUG [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieve the processes (with enabled auto recovery flag) that are in 'Waiting' or ‘Running’ or 'Blocked' states and contain operators in 'System Error' when ran against: TP_user01-w500.
2011-03-28 19:23:00,015 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 1 processes to recover for TP_user01-w500 recovery.
2011-03-28 19:23:00,015 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Queueing recovery of process with ROID - 2889 for TP_user01-w500 recovery. 2011-03-28 19:23:00,015 DEBUG [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Special Response for process recovery. ROID is 2889 UUID is 3fe95f08-a347-4d6d-a0a3-b3639836e130 2011-03-28 19:23:00,015 DEBUG [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Special Response for process recovery was posted. ROID is 2889 UUID is 3fe95f08-a347-4d6d-a0a3-b3639836e130 2011-03-28 19:23:00,015 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Queued requests for Touchpoint: TP_user01-w500 Recovery... Recovering Processes with the following ROIDs: 2889
2011-03-28 19:23:00,015 DEBUG [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Touchpoint: TP_user01-w500_2 mapped to Agent: f3492322-5517-4a21-8a19-92838ccb3f65 is not set to Automatic Recovery of 'System_Error' operators in 'Waiting' or ‘Running’ or 'Blocked' Processes.
2011-03-28 19:23:00,015 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: TP_user01-w500_3 Recovery. Recovering 'System_Error' Operators that ran against: TP_user01-w500_3 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set). 2011-03-28 19:23:00,015 DEBUG [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieve the processes (with enabled auto recovery flag) that are in 'Waiting' or ‘Running’ or 'Blocked' states and contain operators in 'System Error' when ran against:: TP_user01-w500_3
2011-03-28 19:23:00,015 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 0 processes to recover for TP_user01-w500_3 recovery. 2011-03-28 19:23:00,031 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Found no Processes to recover for Touchpoint/Orchestrator: TP_user01-w500_3 Recovery.
2011-03-28 19:23:00,031 DEBUG [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Touchpoint: TP_manyAgents mapped to Agent: f3492322-5517-4a21-8a19-92838ccb3f65 is not set to Automatic Recovery of 'System_Error' operators in 'Waiting' or ‘Running’ or 'Blocked' Processes
2011-03-28 19:23:30,015 INFO [com.optinuity.c2o.workflowengine.FlowManagerCache] [onPool Worker-3] Registering flow manager: 2889 2011-03-28 19:23:30,015 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Handling Response: [$$TouchpointRecovery&&]. flow id is 2889 2011-03-28 19:23:30,171 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Start Recovery of Process with ROID:2889, for TP_user01-w500 Recovery.
2011-03-28 19:23:30,171 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Resetting System_Error Operators in Process with ROID: 2889 for TP_user01-w500 Recovery. 2011-03-28 19:23:30,203 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Resetting Operator with ROID: 2912 in Process with ROID: 2889 for TP_user01-w500 Recovery.
2011-03-28 19:23:30,343 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Resuming Process with ROID: 2889 for TP_user01-w500 Recovery. 2011-03-28 19:23:30,343 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Resuming WorkFlow - ROID is 2889 2011-03-28 19:23:30,703 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [onPool Worker-3] Done resuming Process with ROID: 2889 for TP_user01-w500 Recovery.
Process 2889 completes successfully. Because the recovery process started automatically, the process logs indicate that the engine initiated the recovery. For manual recovery, logs include the name of the user who started the recovery.
2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: HG_user01-w500 Recovery. Recovering 'System_Error' Operators that ran against: HG_user01-w500 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set). 2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 0 processes to recover for HG_user01-w500 recovery. 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Found no Processes to recover for Touchpoint/Orchestrator: HG_user01-w500 Recovery... 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: TP_user01-w500 Recovery... Recovering 'System_Error' Operators that ran against: TP_user01-w500 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set). 2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 0 processes to recover for TP_user01-w500 recovery. 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Found no Processes to recover for Touchpoint/Orchestrator: TP_user01-w500 Recovery... 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Initiating Touchpoint/Orchestrator: TP_user01-w500_3 Recovery... Recovering 'System_Error' Operators that ran against: TP_user01-w500_3 and belong to 'Waiting' or 'Running' or 'Blocked' Processes (with auto recovery flag set).
2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 1 processes to recover for TP_user01-w500_3 recovery. 2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Queueing recovery of process with ROID - 541 for TP_user01-w500_3 recovery. 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Queued requests for Touchpoint: TP_user01-w500_3 Recovery... Recovering Processes with the following ROIDs: 541 2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Retrieved - 1 processes to recover for TP_user01-w500_3 recovery. 2011-03-28 19:23:41,444 WARN [com.optinuity.c2o.workflowengine.C2oWorkFlowEngine] [aListenerThread] recoverSystemErrorProcesses: Queueing recovery of process with ROID - 541 for TP_user01-w500_3 recovery. 2011-03-28 19:23:41,444 INFO [com.optinuity.c2o.c2oserver.ServerManager] [aListenerThread] Queued requests for Touchpoint: TP_user01-w500_3 Recovery... Recovering Processes with the following ROIDs: 541
2011-03-28 19:24:11,461 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Handling Response: [$$TouchpointRecovery&&]. flow id is 541 2011-03-28 19:24:11,804 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Start Recovery of Process with ROID:541, for TP_user01-w500_3 Recovery. 2011-03-28 19:24:11,820 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Resetting System_Error Operators in Process with ROID: 541 for TP_user01-w500_3 Recovery. 2011-03-28 19:24:11,883 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Resetting Operator with ROID: 564 in Process with ROID: 541 for TP_user01-w500_3 Recovery. 2011-03-28 19:24:12,039 INFO [com.optinuity.c2o.workflowengine.C2OSvcIconInstanceRefObject] [nPool Worker-63] Inside Update ConnectorTraversed, Current/destination is Start_System_Process_1 Source is Start_1 2011-03-28 19:24:12,117 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Resuming Process with ROID: 541 for TP_user01-w500_3 Recovery. 2011-03-28 19:24:12,117 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Resuming WorkFlow - ROID is 541 2011-03-28 19:24:12,133 INFO [com.optinuity.c2o.workflowengine.C2OSvcIconInstanceRefObject] [nPool Worker-63] Inside Update ConnectorTraversed, Current/destination is Start_System_Process_1 Source is Start_1 2011-03-28 19:24:12,648 INFO [com.optinuity.c2o.workflowengine.WorkflowManager] [nPool Worker-63] Done resuming Process with ROID: 541 for TP_user01-w500_3 Recovery.
