You can create custom operators in any library folder.
The Select Base Operator dialog appears.
A custom operator object with a default name is created in the library.
Note: The application identifies custom operators by a unique location in the library using the object path and name. Avoid changing the location and custom operator object name if it is currently being used in a process. Renaming or moving a custom operator while it is used in a process can result in the loss of changes or updates.
