Timeout settings give the users ability to set a timeout as part of every operator. If the operator has not finished by the specified time defined in the Timeout settings, the execution takes a timeout exit port. Users still retain the choice to end the execution of the operator and take the timeout path or let the operator continue with the execution.
Timeout settings have the following properties:
Specifies that there is no timeout set for the operator (enabled by default).
To specify a timeout value, clear the No Timeout check-box.
Specifies the type of timeout. Select one of the following timeout types.
Specifies the timeout duration in seconds.
Specifies the timeout date (MM/DD/YYYY) and time (24 hours).
Defines the timeout duration or the target date for the operator.
You can select a timeout action from the following:
Specifies the flow is abandoned after the timeout of the operator. The following actions are performed:
Specifies the flow is aborted after the timeout of the operator. The following actions are performed:
Specifies the flow continues after the timeout of the operator. The following actions are performed:
Specifies the flow is reset after the timeout of the operator. The following actions are performed:
