You can restrict which objects a specified CA Process Automation user can view and the actions that user can perform. You can create CA EEM rules such that a user can only see or use one automation object instance or one automation object. This type of access is possible only when content designers work with library objects in working folders. In this case, the release versions of objects are copied to a release-specific folder for export as a content package.
Note: Log in to CA Process Automation as the specified user and verify that the access is correct.
