Administer Advanced CA EEM Security › Customizing User Access with CA EEM Policies › How to Customize Access for a Default Group › Create a Custom Policy Based on an Existing Policy
You can create a custom policy based on a default policy or based on another custom policy.
CA Process Automation provides a policy for almost all resource classes. You can modify default policies directly since they are editable. However, there is no easy way to revert to the original. You can institute a practice that preserves the predefined policies so you can compare a revision with the original or revert to it.
- Browse to CA EEM and log in.
- Click Manage Access Policies.
- Click the name of the access policy to modify.
- Click the policy link in the policy table.
- Click Save As and enter a custom policy name.
- Click Save.
- If the custom policy is to replace a predefined policy, open the predefined policy and click Disable. Then click Save.
Note: Your custom policy is ready for customization.
