The need to maintain IP addresses and or names can arise. Examples follow:
Modify the name and IP address combination wherever they appear in the following files.
install_dir/server/c2o/.config/OasisConfig.properties
install_dir/server/c2o/.config/Domain.xml
Note: To continue to use an unchanged host name in all references in CA Process Automation, modify the DNS with the new IP address.
install_dir/PAM Agent/PAMAgent/.config/OasisConfig.properties
Change the value of the following property:
oasis.jxta.host
To get CA Process Automation to bind at the external IP address, add the following property to OasisConfig.properties:
jboss.bind.address=xxx.xxx.xxx.xxx
