Administer Agents › Add an Agent Touchpoint
When you install an agent on a host, the agent display name appears under the Agents node. For an operator to be able to target that host, you configure a touchpoint that references the host.
- Click the Configuration tab.
- Expand the Agents node.
- Right-click the agent and select Configure touchpoint at, then select the environment.
A prompt to lock the selected environment appears.
- Click Yes to lock the selected environment.
The Add Agent Touchpoint dialog appears.
- Enter a name for the new touchpoint that is different from the host name, and click OK.
The new touchpoint appears under the All Touchpoints node for the associated environment.
- Click Save.
- Select the locked environment and click Unlock.
More information:
Administer Touchpoints
Administer Proxy Touchpoints
