Administer Environments › Configure the Contents of an Environment › Specify Trigger Settings for an Environment
Trigger settings are disabled at the environment level by default. If trigger setting have been configured at the domain level, you can specify that you want to inherit these settings. Alternatively, you can enable a trigger and then override the domain-level settings. If needed, you can disable a trigger that is enabled or set to inherit values.
- Click the Configuration tab.
- Review the Domain-level settings for the trigger:
- Click Domain
- Click the Triggers tab.
- Double-click a trigger.
- Determine whether the trigger has been configured, and if so, whether to accept the settings for a given environment.
- Select an environment and click Lock.
- Select a trigger.
- Select a new value from the drop-down list
- Inherit from Domain
Specifies that the settings configured at the domain-level are used in the selected environment.
- Disabled
Specifies that this trigger is not used in this environment.
- Enabled
Specifies that this trigger is to use the settings configured for this environment.
- If you select Enabled, then right-click the trigger and select Edit. Edit the settings using the following as a guide:
- Click Save.
- Click Close.
- Select the updated environment and click Unlock.
